587,818 active members*
2,804 visitors online*
Page 1 of 2 12
Results 1 to 20 of 34
    Apr 2012
    126
    how high is the mini mill
    how high is the mini mill when the z is down ? u`d like to see if it will come into my garage door. my door is a 7 footer .
    Jan 2006
    2985
    Neglecting the cable chain the height is 101" max. Subtract the z travel of 10" and you are still well over 7'.
    http://haascnc.com/DOCLIB/dimensions...ne%20Views.pdf
    Apr 2012
    126
    what if i removed all the components , motor , covers .
    Jan 2006
    2985
    Obviously you could disassemble it enough to fit. I think it would be a question to ask Haas. You might get something useful from this: http://www.cnczone.com/forums/haas_m..._minimill.html
    Matt
    Jan 2005
    15362
    magnum500sw
    I have put them in a 86" door opening, it was a easy fit I don't know how much I had to spare, but never removed anything, You need long forks & a low 5000lb fork lift
    Mactec54
    Jan 2005
    15362
    keebler303
    The Z travel on a minmill has 14" of travel, 10" is the tool change height
    Mactec54
    Apr 2012
    126
    my door opening is 84" thats the max size . would it go in that opening ?
    Jan 2006
    2985
    keebler303
    A minimill is 10".
    Haas MINIMILL | Haas Automation, Inc. | CNC Machine Tools
    A minimill2 is 14"
    Jan 2005
    15362
    keebler303
    A minimill is 10".
    Not correct a minmill has 14" of travel in the Z axes, as I said the 10" is the tool change height, it is obvious you do not own one, a minimill2 has 4" more in all axes than the minimill
    Mactec54
    May 2004
    4519
    Tomorrow morning, call these guys on the telephone and they can answer your question:
    2800 Sturgis Rd.
    Oxnard, CA 93030
    Phone: 805-278-1800
    Toll Free: 800-331-6746
    Jan 2005
    15362
    txcncman
    Why would you need to, it's all in the spec of the machine, 14" for the minmill & 18" for the minimill2 , the number 10" is for the tool change height, there is 4" more above this height, the minimill2 toolchange height is 14" + 4" above
    Mactec54
    Apr 2012
    126
    so will it fit in a 84" door ?
    May 2004
    4519
    txcncman
    Quote Originally Posted by magnum500sw View Post
    This is why he needs to call the source.
    Apr 2012
    126
    i was hoping to have a member here that owns a mini take 5 min and run the z down as far as it can go and do a quick measure for me , i`m thinking the mini will scoot under that door with the motor covers off but would like to know what i`m in for befor i put the $$ down .
    Oct 2010
    103
    If the machine will even fit under your ceiling at its max height, I think it would be easier, cheaper, and less time consuming to knock out your doorway to make it fit. Thats just my thought
    Apr 2012
    126
    that would be an option but the paint in that part of the addition is barely dry . in other words she`d kick my ....$$ . if i was single it would be done .
  17. #17
    Jan 2006
    2985
    keebler303
    A minimill is 10".
    You are correct I don't own one. Not trying to ruffle any feathers.
    Why do they state the travel as 10 when it's 14 and list min and max spindle to table dimensions as 4 and 14? Seems odd.
    Matt
  18. #18
    Jul 2005
    12177
    Quote Originally Posted by keebler303 View Post
    ...Why do they state the travel as 10 when it's 14 and list min and max spindle to table dimensions as 4 and 14? Seems odd. Matt
    Somewhere in the literature or manual for my MiniMills and Super MiniMills there was an explanation. The 10 inches of travel down from the tool change position is the useable travel and the other 4 inches above the tool change position is not useable because the linear guides are not fully supported so the head is not as rigid against side loading.
  19. #19
    Oct 2010
    103
    Well, the newer it is, the easier it would be to match things back up and to match up (structure, color, etc...).
  20. #20
    Apr 2012
    126
    Quote Originally Posted by annoying View Post
    your not married are you ?
    i called haas as recommended and the sent me some info , if i loosen the conduit flanges it will go down to 78.5 " remove the head cover and a regen resistor and get 75 " . this looks like info for an older machine like in the early 2000`s to 2010 , umbrella style . looks like i`m in buisness .
Page 1 of 2 12
  1. High Quality Mini-mill
    By FabbersRu in forum Want To Buy...Need help!
    Last Post: 04-24-2012, 06:22 PM
  2. Tramming a LMS high torque mini mill...
    By J S Machine in forum Benchtop Machines
    Last Post: 08-29-2011, 02:36 PM
