Even though I've been up and running for some time I'm still a newbie in many ways. I noticed that a slot running x to x was slightly wider than a slot cut with the same code running y to y. I decided to adjust my motor tuning in Mach to make them the same. Nearly drove me crazy looking for a setting that would produce a given travel. Of course, that gets to repeatability. So I decided to focus on that first. I securely fastened a digital caliper to my Y rail and opened it as wide as it would go. Then I slowly jogged down until my carriage began closing the caliper. When it got a little above 4" I zeroed the Y and zeroed the caliper. Then I gave Mach the command to move to minus 4". After each cycle I wrote down the numbers. Then I returned the carriage to Y zero, zeroed the caliper and repeated the cycle. I did this five times and got the following numbers: -3.9765, -3.9775, -3.9760, -3.9755, -3.9775. Subtracting the smallest from the largest gave me a difference of 0.020". I wonder how that stacks up in the world of CNC routers in general. I would appreciate any feedback.
