Typical plasma height controls have initial height sensing for piercing as well as during travel which prolong nozzle life. And the auto height ensures the arc voltage remains constant which also prolongs consumable life. Consistant cut quality is also a benefit.
Also Keep in mind that most CNC tables use a torch that is water cooled due to the usually higher duty cycle of a CNC table. If you cut thin material that is likely to warp with cutting, it may get a bit messy for continuous operation.
Al
Albert E.
