603,980 active members*
2,230 visitors online*
    May 2007
    250
    How to increase the jog speed of Mach3?
    Dear All,
    I have both mach2 and mach3 software.
    I can increase the jog speed of mach2 by pressing Shift + Arrow(left
    and right)
    I don't know how to increase the jog speed of mach 3. How to do?
    Best Regards,
    Mongkol
    Dec 2004
    1865
    Quote Originally Posted by Mongkol View Post
    Dear All,
    and right)
    Best Regards,
    Mongkol
    The shift= direction bypasses the % of max jog that you can see by hitting the tab key and looking at the pendant like popup to the max setting
    If the shift =+direction doesn't go any faster, you may have to raise the max motor speed under motor tuning. Just make sure you don't set the motor tuning any faster than the machine will go.
    Mike
    Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out.
    Jul 2007
    165
    Re: How to increase the jog speed of Mach3?
    Sorry to resurrect this one, but just want to sense-check something I'm seeing in Mach3.
    When I use the keyboard to jog the machine, I'd expect the motors to move at the maximum speed defined in 'Motor Tuning'. So that's equivalent to a G0 (rapid) move.
    However.... the homing speed which is defined in home/limits config also seems to affect this. So if the homing speed is set to 50% this appears also give me a 50% (of maximum) jogging speed from the keyboard. I mention this since I can't see this documented anywhere.
    Normal rapid moves are of course unaffected and are determined by the motor tuning settings only.
    Have I interpreted this correctly? Thanks!
  1. Would like to increase IPM cutting speed
    By Joe Weldor in forum Stepper Motors / Drives
    Last Post: 02-28-2011, 03:19 PM
  2. How to Increase Speed with Mesa and EMC
    By TZak in forum LinuxCNC (formerly EMC2)
    Last Post: 04-01-2008, 07:44 AM
  3. Possible to increase spindle speed?
    By jinu117 in forum Syil Products
    Last Post: 12-24-2007, 03:20 PM
  4. How do I increase spindle speed?
    By cnczoner in forum CNC Machine Related Electronics
    Last Post: 07-11-2007, 02:42 PM
  5. Excellent, Speed Increase
    By snoyce in forum DIY CNC Router Table Machines
    Last Post: 04-04-2007, 08:06 PM
