587,613 active members*
2,961 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to join carbide to withstand high temps?
Results 1 to 5 of 5
    Aug 2007
    105
    Hi all, I have a somewhat strange question. I have to opportunity to use a bunch of scrap carbide to make a sculpture. I know I can join carbide to carbide with brazing, but the brazing won't hold up in high temperatures(think propane flame).
    Does anyone know an easy way to join 2 pieces of carbide that's relatively heat-proof??
    Thanks in advance.
    Jan 2007
    355
    Not sure exactly what you have in mind... how about 3000 degree castable refractory cement?
    Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
    Aug 2007
    105
    looked into it and it sounds promising, will it bond to carbide??
    Jan 2007
    355
    I can't say - because I've never tried. My only experience with refractory cement was in building an electric kiln for metalcasting. Used it to join lightweight firebrick for the kiln base and lid. The brick is incredibly light and porous, and bonds well to the cement.
    There are different curing techniques, depending on the type of refractory cement you're using.
    Will your sculpture be subjected to high temps after it is completed? Can you give more details?
    Mar 2006
    158
    Silver braze will hold up to oxy-acetylene, unless the parts are so small that you wil be heating parts that are allready joined. In which case, the silver solder will flow again.
  1. spindle temps?
    By xaruum in forum Taig Mills / Lathes
    Last Post: 07-26-2010, 03:22 AM
  2. Withstand the Test of Time with Simplicity® Technology
    By Pacific Bearing in forum News Announcements
    Last Post: 03-10-2009, 04:05 PM
  3. High Quality Carbide Burrs
    By rjsupply in forum MetalWork Discussion
    Last Post: 03-27-2008, 06:28 PM
  4. SX3 Spindle/Head temps
    By extrapilot in forum Syil Products
    Last Post: 11-11-2007, 07:32 AM
  5. Painting hardwood sign to withstand direct sunlight/wx
    By spoiledbrat in forum WoodWorking Topics
    Last Post: 07-09-2007, 05:05 PM
