603,373 active members*
3,733 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > how to load a program in fanuc 6t?
Results 1 to 5 of 5
    Sep 2009
    19
    i nee to load a program into the memory CNC fanuc 6t-A,hitachi seike
    5NE ,does anyone know the steps? ??
    Feb 2006
    992
    Hardware tool required:
    DNC software
    Rs232 cable
    inverter
    Software required:
    check your machine parameter manual for I/O data
    go on this webpage http://www.aggsoft.com/cnc-dnc/ and download the setting you need, put the information in the DNC and machine.
    Good luck!!
    The best way to learn is trial error.
    Sep 2009
    19
    I put The DCN settings,but i can't load the program....
    I found the following procedure to load prgram data into the memory (fanuc 6t A) when the number of program numbers is one:
    1-set the lock key to write
    2-set the mode selector key to Tape EDIT
    3-set the control tape to tape reader((((this step i don't know how to do it?)))
    4-Press the READ key
    5-set the lock key to LOCK.
    6-when the RESET key is pressed while in the tape edit mode,the tape is rest to head of the program.
    is what I do to cnc, but this does nothing, some people tell me that when the CNC is ready to receive the information of the program, the initial LSK cominezan to flicker but this kind are not to be done.
    but some people tell me ,some machine(CNC) when are ready to receive the program the initial LSK start flashing....but i don't nkow when the machine is ready to receive,or something to indicate...
    Feb 2006
    992
    Feb 2010
    The same problem
    Hi yumuri,
    I do the same procedure as you but not thing change!
    Did you solve your problem?
    thanks
    sami
  1. FANUC 31i load program
    By Bama in forum Fanuc
    Last Post: 04-18-2010, 09:22 AM
  2. How Do I Load a Program?
    By ranchak in forum Bridgeport / Hardinge Mills
    Last Post: 09-04-2009, 07:48 PM
  3. Can't load program to Fanuc 21i-m
    By dpy in forum DNC Problems and Solutions
    Last Post: 04-09-2009, 11:18 AM
  4. Can not load a program via MDI
    By steelhead9 in forum Fanuc
    Last Post: 01-22-2009, 05:31 PM
  5. Doesnt load all of the program?
    By dafowfidy in forum Mach Mill
    Last Post: 08-07-2008, 02:00 AM
