587,082 active members*
2,849 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > How low can I drop my rpms on my spindle?
Results 1 to 13 of 13
    Mar 2017
    173
    Hi guys
    I have a 2.2kw water cooled spindle and my vfd is the askpower 131. I attach the manual of my vfd.
    I have been dropping it as low as 100hz which means 6000rpm. I would like to know if I can drop it lower without hurting the spindle. Say 50hz or even lower if possible?
    Mar 2017
    173
    Re: How low can I drop my rpms on my spindle?
    Anyone has any info?
    Nov 2013
    4474
    yes you can drop it lower but you won't get any increase in torque.
    Many spindles are air cooled and because the fan the fan slows as the spindle running such spindles at low speed is to risk a bad overheat situation.
    Your spindle being water cooled is less prone to overheat, but if you notice it getting hot stop immediately.
    A 2.2kW spindle has a rated torque of:
    T= (24000 / 60)*2*PI /2200
    =1.14Nm
    So don't expect to drive a 10mm tool in steel, in fact without taking light cuts a 6mm tool will stall a 1.14Nm spindle.
    Craig
    Jan 2005
    15362
    Quote Originally Posted by jimskeet View Post
    Hi guys
    Only if the Spindle you have has a 3000 RPM rating which some do, it won't have any useful torque below 6,000 RPM and most don't go below 7,200=120Hz as they mostly cut at this speed, at 6,000 RPM they barely make it and have a high possibility of stalling, once you stall your spindle damage is quite possible
    Mactec54
    Mar 2017
    173
    I want to drive 3mm tool to take light cuts on stainless. Like 0.3mm stepdown passes.
    I have run it at 6000 rpm very often.
    Nov 2013
    4474
    you can run 24000 rpm asynchronuos spindles slowly but they are far from their optimum.
    I was so dissapointed that my 24000 rpm spindle could not be run slowly and that it has so little torque to render it almost
    useless in steel and stainless that I made a second spindle using a direct coupled 1.8kW AC servo, 3500rpm, 6.2Nm comt, 18Nm
    overload. Works a treat in steel and stainless.
    Craig
    Mar 2017
    173
    Thanks for the info
    Mar 2017
    173
    Hi guys.
    I am bringing back the topic.
    Is it safe to run 6 and 8 mm drills at 3000rpm or lower to drill wood with the 2.2kw chinese watercooled spindle? The drilling operation I need is one 8mm and one 6mm holes that are 35mm deep. I do them at 6000rpm now but I would like to do them with lower rpm if possible. Any thoughts?
    Dec 2003
    24223
    Running them lower than the recommended limit can result in a burn out of VFD and/or motor.
    The inductive reactance of the motor is so low at the lower frequencies, it has to be kept in the higher range otherwise the current/heat is destructive.
    Al.
    Albert E.
    Mar 2017
    173
    Thanks for the answer. The operation lasts a few seconds. You think it is enough to create a problem?
    Dec 2003
    24223
    Depends if you want to roll the dice!
    O/L can happen in milli -seconds!
    Albert E.
    Mar 2017
    173
    Got it.
    Thanks again
    Jan 2005
    15362
    Got it.
    Thanks again
    There are some of these spindle that can run at 3000RPM but they have a higher torque than the standard and there amp rating of 10.5a is higher for the 2.2Kw spindle, they have a longer body and rotor
    Just remember a drill requires more torque than milling so if you go to low and stall your motor then you will damage it and the drive, it may take it a few times before total failure
    Get quality drills and they will run ok with coolant at the 6000 RPM most likely your minimum speed below 6000RPM there is no useful torque with these motors and even at 6000 RPM most find 7200 RPM is around what most find as an ok running speed as far as torque goes
    Mactec54
  1. Mach 3 - A-axis feed + Spindle rpms
    By JTMN in forum CNC Machine Related Electronics
    Last Post: 11-25-2019, 04:46 PM
  2. Pulleys for high RPMs, stock motor and spindle
    By cncuser1 in forum Benchtop Machines
    Last Post: 12-08-2018, 03:23 AM
  3. Any way to get more torque out of the 770 spindle motor at low RPMs?
    By mrquacker in forum Tormach Personal CNC Mill
    Last Post: 04-11-2016, 07:06 PM
  4. Spindle RPMs and feed rate issue
    By dminnery in forum WoodWorking Topics
    Last Post: 04-28-2012, 09:54 PM
  5. Replies: 0
    Last Post: 05-11-2011, 12:00 AM
