603,354 active members*
3,668 visitors online*
    Mar 2004
    636
    How to machine E/G
    With all the reading here, I still have not found "best practices" machining Epoxy Granite. What is better, a mill or router and what type of tooling? Is carbide sufficient, or is a diamond tool needed?
    thanks
    Dan
    Check out what I am working on at www.routerbitz.com!
    Mar 2004
    636
    Bump
    Thoughts, Ideas, Tips or Tricks?
    Dan
    Mar 2003
    35494
    Probably the same as cutting stone, as EG should be more than 85-90% stone.
    Which means diamond tools flooded with water.
    Just guessing, though.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  1. Replies: 3
    Last Post: 08-03-2013, 11:14 PM
  2. Sell CNC router ,CNC engraving machine ,CNC laser machine
    By kelvinguo in forum CNC Machining Centers
    Last Post: 10-07-2010, 06:39 AM
  3. Deep Groove Taig machine would it be a good starter machine
    By Fritzie15 in forum Taig Mills / Lathes
    Last Post: 09-21-2007, 03:37 AM
