Need some insight on how to go about Machining the two front bosses and front arc.
I'm using a cheap grizzly mill. I was thinking about doing the following
1. Center rotary table to end mill
2. Scribe a center point between the 2 screw holes and the locating bosses
3. Mount cross slide vise to rotary table
4. Mount part in vise and aline center point to end mill. Perfectly over center point of rotary table.
This should allow me to say move .5" on the x and .250 on y and machine the front locating boss because it would be directly over the middle of rotary table.
Then move -.5 on y and do the other one
Then move - on x to machine the screw holes
Return to center to machine thw three inch radius.
Does this sound like it will work? Does a cross slide vice even have a scale?
