603,979 active members*
1,365 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to machine this part?
Results 1 to 14 of 14
    Jan 2007
    260
    Hello fellow MC users...
    I was wondering if anyone of you can offer some insight as to the best approach to machine this part. I know it it very simple, and I can do some simple pocket cuts, but notice how one edge is at an angle.
    If I was going to machine this from the top (as the wcs is currently oriented) is there a way to machine the tenon part, while maintaining the angle on the edges? I guess this is what I need help with, but I could not figure out a toolpath in mastercam to help me do it. I know there is probably some parameter which I am not providing MC. Using MC x2.
    Any help would greatly be appreciated...thanks in advance!
    Attached Files Attached Files
    Jan 2008
    27
    was gonna try to help....but I keep getting a corrupt file message
    I'm working with MX2
    what machine you working with,
    Fadal I hope
    G Code .cam .gcd .nc pt4 (proto trak)
    send you'r file to [email protected]
    just send you'r DXF DWG file (or any other Master cam compatable file)
    Jan 2007
    260
    Hey thanks!
    Here is the file in parasolid binary format....
    Apr 2003
    3578
    I did this with tow different tools one a .25 sharp and a .25 ball to let you see both. I used flowline for the path.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Jan 2007
    260
    there is a lot more to flowline than I thought!
    Thanks! That looks promising...now to actually go cut it...from the simulation it seems pretty straight forward.
    THanks again for taking the time to look at this.
    Apr 2003
    3578
    Hope that helped. Let me know how it goes.
    Cadcam
    Oct 2007
    68
    Simple part ...
    Hello all MC users
    I got the same problem
    2D work fine, but solid so hard for me
    I already try parallel toolpath,and contour toolpath, but have not success
    Anyone know how to program this part please drop for me a tips or short tutorial I will appreciate your help
    Thank you in advance
    Apr 2003
    3578
    Review this one.Of to santa barbra with the kids for the day.
    Cadcam
    Oct 2007
    68
    Thanks CadCam
    Your program look very good ,but we need to make 2 ops to finish the contour,the way cutting not perfect
    programming this part on 2D is better than programming on solid
    Thank you so much
    Apr 2003
    3578
    I am not sure what you are saying as this was 2D cutting. Are you saying not as a good because I have to ops to finish?
    I also can do in one op I chose two do to the shape and making more effecent path.
    Cadcam
    Oct 2007
    68
    OK!Now I understand why you make 2 ops
    Thanks you so much
    Feb 2008
    8
    need help to draw a part and creating toolpaths
    I was wondering if anyone of you can help me make this part. I understand it to be very simple for MC users. This just doesn't happen to be my field of expertise. and I have just started learning the basics to creating geometry in mastercam. I need to machine this part in my uni workshop's CNC milling machine as part of an assignment.
    Using MC x2.
    thanks in advance!
    Oct 2007
    68
    The first drawing look so confuse to me.
    Your drawing missing some dimension, radius and depth,
    I use Solid Sweep to make an example cut
    Take a look at the attach file
    Feb 2008
    8
    the profile of the curved surface is defined by a parabola y=1/170 x(square)
    the way i can think of doing it is, creating the parabola and then revolving it 360. and then superimposing the resulting paraboloid on the base and then doing a boolean subtraction. or is there an easier way of doing this.?
  1. Machine won't cut out my part!
    By CROSSHATCH in forum Uncategorised CAM Discussion
    Last Post: 01-08-2008, 01:41 AM
  2. How can I machine this part?
    By scubasteve_911 in forum MetalWork Discussion
    Last Post: 09-05-2007, 07:48 PM
  3. how to machine this part
    By star1280 in forum MetalWork Discussion
    Last Post: 06-13-2007, 09:14 PM
  4. Machine Down Need Part Bad!!!!!
    By joe1970 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-30-2005, 12:36 AM
