587,687 active members*
3,494 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to make/cut an inner guide on aluminium pipe - suggestions
    Jun 2013
    4
    Hi to everyone. I am real newbie and I need help on deciding how to cut inner guide on an aluminum pipe (D80, 5mm wall thickness). I need three inner cuts to be straight all through the pipe (lengths of 2, 3 or 5 meters).
    Cut is 1mm deep.
    I was thinking to use another thinner pipe and a brute force with some cutters mounted on it. For example D70 pipe to cut D80 one. Will it work? Or something similar?
    Thanks to everyone for suggestions. Hope this is a right place to ask something like this..
    Attachment 452812
    Goran
    Nov 2007
    479
    Re: How to make/cut an inner guide on aluminium pipe - suggestions
    Look into broaching.
  1. Can anyone make me this part or know where I can find it? 30mm ID pipe. 2mm wall
    By trialanderror in forum Uncategorised MetalWorking Machines
    Last Post: 09-01-2012, 08:41 AM
  2. Cross Roller Guide Cage:Brass or Aluminium?
    By me081company in forum Linear and Rotary Motion
    Last Post: 11-03-2011, 01:21 PM
  3. Gantry on outside of y axis guide pipe
    By andydoc in forum Commercial CNC Wood Routers
    Last Post: 12-29-2005, 10:20 PM
