587,739 active members*
3,248 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > how to make my custom Machine file
Results 1 to 7 of 7
    Dec 2010
    is it possible to build my own machine file then simulate my custom Machine, if yes how to do this ...
    Jun 2011
    Can you elaborate a bit more and I maybe able to help you!!
    Eoin
    Dec 2010
    for example i have custom machine like this one
    i want configure rhinocam based on my custom machine
    then put it here
    Jun 2011
    I assume you mean that you have a five axis mill an you want RhinoCAM to generate tool paths and then to post process the GCode??
    If this is what you mean then yes RhinoCAM can post process five axis....but.....you'll need to purchase the RhinoCAM 2012 Expert 5axis version it's a bit pricey though......and RhinoCAM WILL generate a custom post processor if you require one.
    Eoin
    Dec 2010
    so there is no way to test befor purchase it ? i want to be sure that will work
    Jun 2011
    Well you could download the trial version and this will simulate the tool paths but you won't be able to post process. .....However MecSoft have publicly stated that they WIll generate any custom post processor for a customer if the vast range of post processors that are available will not suit a customer. ....
    Jun 2011
    How are you gettting on with the trial version
    Eoin
  1. In search of someone to make custom molds
    By HoustonTexas in forum Moldmaking
    Last Post: 08-05-2012, 09:48 AM
  2. How to make custom lathe tool
    By slammers in forum Mastercam
    Last Post: 11-08-2010, 11:16 AM
  3. Anyone make a custom 4th and 5th axis?
    By carbidecraters in forum Fadal
    Last Post: 07-01-2008, 05:37 AM
  4. Using CNC mill to make custom car emblem
    By david90 in forum Uncategorised MetalWorking Machines
    Last Post: 02-01-2008, 12:05 AM
  5. How hard to make a custom cnc spindle?
    By rlevin in forum MetalWork Discussion
    Last Post: 09-01-2006, 07:44 PM
