588,606 active members*
8,088 visitors online*
    Nov 2006
    99
    Red face How many power supplies??
    Ok have a couple of questions how many power supplies will i need for this set up 3 nema 23 steppers at 3.6V/Phase 2.4A/phase.
    2. each motor has its own driver board that i got from pminmo the http://pminmo.com/forsale/1X279805.pdf
    May 2006
    21
    Quote Originally Posted by biotech1 View Post
    I think you could use 1 (24v) 6amp power supply (shared between 3 boards.
    Or you could use 3 (24v) 2amp power supplies (one for each board)
    Just make sure you don't exceed the maximum voltage the boards can handle and make sure the power supply/supplies can supply enough amps.
    Feel free to correct me if this is wrong.
    Nik
  1. power supplies.
    By LeeWay in forum Gecko Drives
    Last Post: 05-19-2006, 11:17 AM
  2. Power Supplies Again
    By tintruder in forum Servo Drives
    Last Post: 02-17-2006, 12:21 AM
  3. power supplies
    By itsme in forum Xylotex
    Last Post: 02-21-2005, 07:40 PM
  4. These power supplies useful?
    By jlawren6 in forum CNC Machine Related Electronics
    Last Post: 08-26-2004, 02:19 AM
  5. Power supplies
    By cncadmin in forum CNC Machine Related Electronics
    Last Post: 07-17-2003, 03:41 AM
