I'm very new to machining, just got a Grizzly G0704, and am trying build a 36" x 48" CNC router, using 80/20 extrusions.
What I'd like to do, is use the G0704 to facemill the surfaces of the X-axis extrusions, so that I can more accurately mount the linear rails without any binding. (The X-axis extrusions will be 1545, about 48" long)
The problem is, how should I go about setting up this milling job? The Grizzly has a max travel of about 18", so I can only facemill a bit before having to reposition it.
I've tried different clamping setups, using the spindle DRO, the vice etc..., but I can't get a consistent surface once I reposition the extrusion. Any pointers for milling very long items that extend beyond the bed?
