586,069 active members*
3,469 visitors online*
Results 1 to 9 of 9
    Apr 2019
    52
    How much current from Kflop I/O?
    good day,
    my need is to configure Kflop/JP6/IO26-35 as output. Anyone know how much current each pin can drive?
    thanks
    May 2006
    4045
    Re: How much current from Kflop I/O?
    Hi geppo_it,
    KFLOP IO can source/sink 16ma. But the first 8 of 10 IO on JP6 (and JP4) have 150ohm pull down termination resistors which uses most of the source current. So IO 34 and 35 can source/sink 16ma and the rest can sink 16ma but only source ~1ma.
    HTH
    TK
    http://dynomotion.com
    Apr 2019
    52
    Hi Tom,
    how can I use IO 26-33 then? Do I need a buffer to drive an optocoupler?
    tks
    May 2006
    4045
    Hi geppo_it,
    What are the specs on the optocoupler? You might connect the Optocoupler + series resistor to 3.3V and have KFLOP sink to GND to turn it on. When the KFLOP output goes high it should go to at least 2.4V which means the optocoupler should see 3.3V - 2.4V = 0.9V and should turn off.
    TK
    Apr 2019
    52
    Tom,
    do you mean a connection as in the attached figure?
    May 2006
    4045
    Hi geppo_it,
    Correct. But by the way internal to KFLOP there is another transitor that will sink to ground when the output is driven low.
    TK
    Apr 2019
    52
    thanks Tom,
    as always you are helpful. I haven't chosen the optocoupler yet ... any advice?
    Apr 2019
    52
    I forgot... i want drive a 24Vcc mini relay (Omron G2RV series)
    May 2006
    4045
    I think the G2RV says it requires 13ma which would be hard to find an opto to drive that directly.
    Our Konnect uses a LTV-847S with a transistor follower:
    (the resistor would not be needed in your case)
    TK
  1. "peak current" or "reference current" configuration
    By Djsilva2005 in forum Automation Technology Products
    Last Post: 09-27-2017, 08:43 PM
  2. DRIVER CURRENT SETUP - MOTOR RATED CURRENT
    By kmin in forum Stepper Motors / Drives
    Last Post: 08-28-2015, 12:17 AM
  3. Are stepper motors rated peak current or RMS current?
    By tauntdesigns in forum Stepper Motors / Drives
    Last Post: 07-25-2014, 04:32 AM
  4. KFlop 4.3
    By John Coloccia in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-03-2013, 07:57 PM
  5. Low Current interface, High Current Motor?
    By Clackvalve in forum CNC Machine Related Electronics
    Last Post: 05-13-2010, 06:42 PM
