587,529 active members*
3,353 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > How to print copy of program ?
Results 1 to 4 of 4
    Jun 2007
    98
    Cent 5 , ML15 and Partner 2
    When viewing my finished program on my PC using the offline simulator , I'd like to print a copy of individual events as they appear on the screen .
    I pressed the print key on the simulated event page , and this makes my printer start up , but it doesn't print the screen .
    I tried the "print screen" on my keyboard , then opened PAINT and tried to paste , but there is nothing there to paste .
    If I search the A: drive , it will read a floppy copy of the program and I can open that in Wordpad and print that way , but this is a copy of the Gcode version of the program .
    How can I get it to print exactly as it appears on the control screen ?
    Bob
    Apr 2007
    28
    You can download a free print screen utility called Gadwin Print Screen, I use it for similiar reasons.
    Oct 2008
    427
    This technique will work on newer versions of the FastCam off-line software:
    If you change the last line in the PATH.DAT file from PRN to C:\file.txt, when you press the PRINT button, you will create a file named FILE.TXT in the root of the C:\ drive. This is a plain text file that you can edit with any text editor.
    Feb 2012
    This is wrong,as PAINT does not have "copy from clipboard" it cannot be done in paint.
  1. Fanuc OT program copy
    By hmc710 in forum Fanuc
    Last Post: 07-22-2010, 10:25 PM
  2. copy program on fanuc series O or OT
    By cuz1007 in forum Fanuc
    Last Post: 01-27-2010, 07:57 PM
  3. cant print?
    By erase42 in forum BobCad-Cam
    Last Post: 11-30-2009, 03:05 PM
  4. Replies: 3
    Last Post: 01-05-2009, 02:36 PM
  5. Copy Program Section?
    By donl517 in forum Milltronics
    Last Post: 10-31-2006, 12:47 AM
