588,205 active members*
4,067 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to profile/contour and avoid areas?
Results 1 to 4 of 4
    Oct 2006
    79
    I'm trying to cut out this profile and keep the cutter from attempting the slots in the rail. In other words I just want the top flat during the profile operation and cut the rails in another setup. I've tried the little bit I know to no avail. Any help is appreciated,
    Shepard
    Sep 2007
    92
    I would create a simple ruled surface covering those slots, drawn on a different level and add those to your drive surfaces and regenerate. should work fine. hope this helps
    Oct 2006
    79
    I'll give it a shot. I'd thought some containment boundry "thing" might work to keep the cutter to the other side of the rail but I haven't been successful with that.
    Oct 2006
    79
    Your suggestion worked perfectly! Thank you.
  1. Adding extra work areas
    By AcryNom in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-16-2007, 07:13 PM
  2. Avoid Prosoftstore
    By gwb in forum MetalWork Discussion
    Last Post: 02-15-2007, 06:27 PM
  3. Router But hope to avoid surprises
    By watzmann in forum Community Club House
    Last Post: 04-19-2006, 02:10 PM
  4. How to avoid stinkin' coolant?
    By ESjaavik in forum DNC Problems and Solutions
    Last Post: 10-11-2005, 12:47 AM
  5. contour profile
    By stevieboy in forum Mastercam
    Last Post: 10-15-2003, 07:40 PM
