603,386 active members*
3,064 visitors online*
    Dec 2007
    15
    How to program sub spindle as a tailstock
    We recently purchased a QTN250MSY.
    Can anyone post a sample program for using a spring loaded center chucked in the sub spindle as a tailstock?
    Feb 2006
    340
    Haven't done it myself, but basically treat it similar to sync spindle milling, but without clamping the sub spindle. It will probably have to be in g-code. Check the programming manual for some subspindle code samples.
    If you need to start the machine with the W axis away from home, you will need to set a parameter to allow that. I forget what one, just call Mazak.
  1. Anyone used sub-spindle as tailstock?
    By TonyW in forum Okuma
    Last Post: 09-01-2015, 06:29 PM
  2. NL2500 using sub spindle as a tailstock
    By MazakMack in forum Mori Seiki lathes
    Last Post: 04-17-2012, 01:17 PM
  3. MT3 Tailstock Spindle Issue
    By LX Kid in forum Shopmaster/Shoptask
    Last Post: 11-29-2011, 11:46 AM
  4. Need Help** How to use HAAS SL30 tailstock in a program
    By Powder_Keg in forum Haas Lathes
    Last Post: 03-11-2009, 09:43 PM
  5. Tailstock spindle needed for project
    By gbowne1 in forum Employment Opportunity
    Last Post: 03-28-2006, 09:23 AM
