I am building a box with a lid. When I cut the inside of the box out I get a nice radius on each corner since the mill is round. I am cutting a lid to fit down in the opening with edges that are flush with the outside of the box. My problem is that I can't figure out what G Code to use so that the corners of the lid that go inside the box are the same radius as the inside corners of the box? I keep getting square corners any time I cut an outside square. I'm guessing the I and J coordinates, but just can't figure out how to get them to do it. Thanks in advance for any help you can provide so that I can get this square peg into the round hole.![]()
Randall
