603,935 active members*
4,604 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > how to remove chuck to use MT2 collet...
Results 1 to 4 of 4
    Mar 2009
    8
    I need to remove my chuck, to install my MT2 collet.
    Harbor Freight X1
    Any tips or tricks?
    shotgunn
    CM X1 (Harbor Freight), Probotix 3-axis kit, cncfusion X1 kit, Shuttle KPC 45, Linux Ubuntu, EMC2, QCad on Mac OS X 10.5
    Mar 2007
    56
    removing MT2 taper from X1
    Basically unscrew the drawbar about 2 turns and tap the top with a hammer. I support my quill by hand rather than clamp it tight in the faint hopes I will not damage the spindle bearings too much. Out has gone the 3/8 drill chuck supplied and because of my fear of damaging the Eastern Bearings I have chosen to permanently fit a taper shank collet chuck to take ER16 collets, no point in larger size as I suspect the plastic gears will melt or end up as plastic chips if I go larger in diameter than 3/8 or 10mm cutters. If I should ever need to use a drill chuck asgain I will fit it with a 3/8 or 10 mm diameter parallel shank and hold it in a collet. Now no more sticking tapers as the collets are released when the cap nut is unscrewed and no more hammering on the drawbar to release the taper.
    John (in UK with a Clarke MCD10 equivalent of the HF 47518)
    Mar 2008
    3655
    Unscrew drawbar a couple of turns, tap with hammer. REMOVE drawbar and chuck drops into your hand.
    Replace with collet and tighten drawbar. Now, there are TWO different threads for these parts. The collet you buy may not have the same metric threads as the drawbar you have.
    In this case, you can either take your collet and present drawbar to Home Depot or Lowes and buy a same-length 3/8-16 bolt, or buy a new drawbar from Little Machine Shop:
    http://littlemachineshop.com/product...2034&category=
    Keep the metric drawbar screwed into the chuck or it may grow legs and be hard to find when you need the chuck.
    CR.
    Jun 2007
    3891
    Quote Originally Posted by Crevice Reamer View Post
    CR.
    in a pinch you can also rethread the m10 drawbar to 3/8-16 but its not ideal of course. theres a few places that sell m10 collets and tooling online, but 99% of the good stuff seems to be 3/8-16.
  1. What collet chuck is this
    By irving2008 in forum MetalWork Discussion
    Last Post: 11-20-2008, 10:05 PM
  2. Air collet chuck for a c3?
    By gazmalman in forum Mini Lathe
    Last Post: 06-16-2008, 12:23 AM
  3. remove drill chuck
    By jwallace in forum Benchtop Machines
    Last Post: 02-23-2008, 08:06 PM
  4. How to remove 12" Kitagawa chuck from LC40?
    By SRT Mike in forum Okuma
    Last Post: 11-24-2007, 02:05 AM
  5. How do I remove a kwik chuck/spindle
    By Andyh in forum Bridgeport / Hardinge Mills
    Last Post: 08-14-2005, 06:28 PM
