603,945 active members*
3,937 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > How to remove handwheel from tailstock?
Results 1 to 4 of 4
    Mar 2010
    Hi all,
    I have a clone 7x10 mini-lathe.
    I bought a new tailstock casting and wanted to disassemble my old one so I could reuse the other parts. I can't seem to get the handwheel off - I took off the nut and the grub screw but the wheel won't come off.
    Any hints?
    Steve
    Jan 2007
    29
    Hi Steve. I had the same problem the first time I dismantled my tailstock. The problem was rust between the handle boss and the screw shaft. I managed by holding he tailstock by the handle and gently tapping the shaft with a brass drift (you need three hands to do this!) and it eventually came out. I cleaned up and oiled the two parts and I have not had a problem since.
    Mike
    Mar 2010
    Thanks Mike,
    With your hint I was finally able to get it off - I used a screwdriver and mallet to (gently) get in between the bracket holding the screw and the hand wheel.
    Steve
    Nov 2009
    4415
    Gear puller?
  1. X-Y table: How do I remove the handwheel from the leadscrew?
    By doorknob in forum Benchtop Machines
    Last Post: 09-23-2010, 07:23 PM
  2. Handwheel Function ?
    By nelZ in forum CamSoft Products
    Last Post: 10-24-2008, 08:10 PM
  3. Handwheel accuracy
    By PhilCote in forum CamSoft Products
    Last Post: 08-14-2008, 12:11 PM
  4. Handwheel command and MPG
    By precourt in forum CamSoft Products
    Last Post: 03-24-2008, 04:14 PM
  5. Handwheel Installation
    By plateroomred in forum CamSoft Products
    Last Post: 05-24-2005, 10:28 PM
