588,243 active members*
4,209 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > How to Retract over fixture toe clamps while drilling
Results 1 to 6 of 6
    Jul 2009
    93
    So I have a haas VF-2 and have a peck drill cycle (G83). I have to retract 1" between holes to clear the fixture toe clamps. well I am cutting 1" of air on every hole. I was just wondering if there was a way to modify the G code so that it would start at .1" and drill the hole but then between the holes it would retract to 1". Any help would be greatly appreciated!!
    Thanks!!
    -Nate
    Dec 2008
    3137
    Usually an R value defines the start of the cycle, called the retract plane
    the initial level is the Z plane the tool is at before processing the drill cycle
    ie
    G0 X0 Y0
    Z2.0 ( initial level )
    G83 Z-1.5 R0.1 Q0.2 F4.000 M98 ( rapids to Z0.1, feed to Z-1.5, rapid retract to Z2.)
    XY
    XY M99 --> stays down( rapids to Z0.1, feed to Z-1.5, rapid retract to Z0.1 )
    XY --> stays down
    XY --> stays down
    XY M98 --> goto Z2 at cycle end
    XY
    M98 is to return to the initail level ---being Z2.0, to clear all after each hole
    M99 would make it go to Z0.1 after each hole --which would put you thru the clamps
    You can put the M code after each hole to cut out the high retracts, but prove it off 1st without the clamps. The M code is modal.
    Jul 2009
    93
    re:
    So for this line of code I would change N132 line the Z to 1.0 not .1? and then on N133 give it a G98 code instead of a G99 code? and that will fix my problem??
    (NEXT CUT - NEXT TOOL)
    (JOB 4 HOLE RANDOM POINT PATTERN)
    (3/16 HOLE)
    N130 T03 M06
    N131 G90 G54 X5.468 Y2.062 S3340 M03
    N132 G43 H03 Z.1 M08
    N133 G83 G99 X5.468 Y2.062 Z-.575 R.1 Q.0938 P0. F15.
    N134 X8.468
    N135 X11.468
    N136 X14.468
    N137 X17.468
    N138 X20.468
    N139 X23.468
    N140 M09
    N141 M05
    N142 G00 G91 G28 Z0.
    N143 M01
    Jul 2009
    93
    re:
    (3/16 HOLE)
    N130 T03 M06
    N134 X8.468
    N135 X11.468
    N136 X14.468
    N137 X17.468
    N138 X20.468
    N139 X23.468
    N140 M09
    N141 M05
    N143 M01
    Quote Originally Posted by Superman View Post
    ie
    G0 X0 Y0
    XY
    XY --> stays down
    XY --> stays down
    XY
    Dec 2008
    3137
    Yep
    Sorry, it should have been G-code G98/G99
    put a higher figure in on N132, so you can actually see the moves, and miss the clamps, even if it had a nut/stud above the clamp
    The P is a dwell, (in seconds) ---not necessary if a zero time, so it can be omitted
    another trick use incremental
    Code:
    N134 G91 X3.
    N135 X3.
    N136 X3.
    N137 X3.
    N138 X3.
    N139 X3.
    G90 ( to set back to absolute )
    G0 (or G80 will terminate the drillcycle)
    G94 ( force feed/min )
    N140 M09
    N141 M05
    G94 should be stated before a toolchange, just in case you copy & paste and change it to a tap cycle and use a feed/rev (G95) in it. The next toolpath would travel very quick.
    Jul 2005
    12177
    I am puzzled. My Haas Manual says M98 is Sub Program Call and M99 Sub Program Return or Loop. Possibly you mean G98 Canned Cycle Initial Poibt Return and G99 Canned Cycle R Plane Return.
    When there are obstructions you should use G98 and set the Z position ahead of the drill cycle high enough to clear them and set R just above the work. The drill cycle will rapid down to R, peck the hole retracting to R and then return to the Z position before moving to the next hole.
  1. Tap retract
    By kendo in forum Okuma
    Last Post: 01-09-2010, 09:11 PM
  2. G81 RETRACT HIEGHT?
    By panaceabea in forum Haas Mills
    Last Post: 05-14-2009, 10:27 PM
  3. Drilling Cycle = Incorrect Retract?
    By dneisler in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-22-2008, 03:06 PM
  4. Chip Breaking instead of full retract peck drilling
    By weaston in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 05-22-2008, 08:10 AM
  5. Retract Height
    By Sanghera in forum SheetCam
    Last Post: 05-30-2005, 05:52 AM
