588,169 active members*
4,370 visitors online*
    Mar 2011
    4
    how to run a subprogran on a mazak
    Good morning.
    I need some help! I am setting this Mazak QTN350MY nexus controller what i traying to do is run a main program and add a subprogram at the end of the main program.
    This the way i have rigth now
    m1
    m98 p1201
    this is the end of my main program
    I start the machine at the end of the main program to see if goes to the subprogram but is going to the begining of the main program again
    Jul 2010
    If you have a % symbol at the beginning of the program, try deleting it and see if that works. Your g code is correct.
    Mar 2011
    4
    I don't have any % symbol on the beginning of the program
  1. Mazak QT-10 T2 manuals --acct w/ mazak?
    By CDTINC in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-21-2012, 05:09 AM
  2. about mazak TMC need help
    By sumangal in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-30-2010, 06:28 AM
  3. Mazak 6pc with machine Mazak 400n
    By anva in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-17-2010, 08:30 AM
  4. Mazak
    By dario0305 in forum CNC Machining Centers
    Last Post: 05-14-2010, 09:34 AM
  5. Mazak QT-200,Mazak VTC-160A,Mazak FJV-250 all pcb problem
    By sting_dot in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-22-2007, 02:20 AM
