Hi there
I need help on selecting the right micro step settings for my machine.
Any recommendation is highly appreciated.
I have two different Pinion gear for my steeper motor, which I place directly on my Stepper motor, and then on my rack. (I need to select the best option from these two pinion)
a pinion with 13 pitch each at 7 mm 13*7 =91 mm
a pinion with 22 pitch each at 7 mm 22*7 =154 mm
I also have a 4.5 N.M (637 OZ-In) 2 Phase NEMA Steeper Motor ( LeadShine)
I also have a M880A (LeadShine) Driver
What would be the best Micro step Resolution Selection for me.
all I require is a smooth motion, with max speed of about 5000 mm/min, and off course the highest possible torque.
Regards
jhonansaro
