587,207 active members*
3,036 visitors online*
IndustryArena Forum > Other Machines > Other Machine Topics > how to set postprocessor for software - SteelTailor Legend I CNC cutting machine
    (Q) I am interesting in a plasma cutting machine for air ducts 1500x3000, regarding air ducts software, which one is the best air ducts software, the one can SteelTailor CNC cutting machine supply?
    (A) Lantek Software:- Lantek Expert Duct is a powerful module for calculating HVAC and Duct figures. It is one of the global leading Duct CAM software’s. SteelTailor CNC cutting machine will be able to support you with this software.
    (Q) How to set postprocessor (Controller) for Lantek software?
    (A) SteelTailor CNC cutting machine will be able to send you the Postprocessor setup file. You need to copy the postprocessor file to you software folder. Please contact our after sales team for details.
    (Q) I have a Legend I CNC cutting machine of SteelTailor, the machine works perfectly still, I see SteelTailor has change the controller, I am wondering if its possible to upgrade my old controller with the new one?
    (A) The Legend I CNC cutting machine controller is a handheld controller, To upgrade the controller you need to make lot of modification, also you need to make space on the electrical box to fix the controller, which will be difficult for you.
    More information about SteelTailor Portable CNC cutting machine FAQs, Pls visit:
    Forum - Powered by Discuz!
    Youtube cut videos
    https://www.youtube.com/watch?v=jF5kkIMyA78
    Hope this is helpful to you .
    Any other question ,pls email at [email protected].
    You can also find us easily on facebook:SteelTailor Twitter:SteelTailor,
    SteelTailor--The world leader of portable CNC cutting machine
    www.steeltailor.com
    May 2014
    Re: how to set postprocessor for software - SteelTailor Legend I CNC cutting machine
    please i need the post processes for yeah legend
    May 2020
    8
    What machine should i install in Lantek Expert v27 so i can generate a compatible G-Code with Dragon 1 CNC from Steel Tailor?
  1. Replies: 0
    Last Post: 03-06-2015, 06:24 AM
  2. Replies: 0
    Last Post: 05-20-2014, 09:46 AM
  3. Replies: 0
    Last Post: 04-28-2014, 09:44 AM
  4. Replies: 0
    Last Post: 01-14-2014, 02:13 AM
  5. SteelTailor Yeah!Legend B5II Economical Table CNC Plasma Cutting Machine
    By Steel Tailor in forum Linear and Rotary Motion
    Last Post: 11-15-2013, 07:19 AM
