603,360 active members*
4,585 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > How to set the time and date
Results 1 to 8 of 8
    Dec 2006
    49
    We have just changed the memory battery in the back of the machine (VF0E) and now the date is wrong.
    Can anyone tell me how to set the date/time again. Many thanks.
    Dom B
    Mar 2005
    1498
    070310-1304 EST USA
    DomB:
    See p21 of the HAAS on-line mill manual. I am not where I can check it now.
    Dec 2006
    49
    Just tried the help key thing as on p21 of the manual, does nothing, I must have an older mocon system. Any other ideas.
    Dom
    Mar 2005
    1498
    070310-1524 EST USA
    When I am at the shop I will check it out.
    Apr 2006
    97
    The control contains a clock and date function. To view the time and date, press the Help button until the date
    and time appears.
    Setting the date and time, use the Up and Down arrow keys to select the date or time. Use the Right and Left
    arrow keys or the jog handle to make adjustments.
    hope this helps
    Mar 2005
    1498
    070310-1700 EST USA
    Checked our 93 machine. Date and time do not exist. Checked 2000 manual and it indicates date at #3011 and time #3012. As usual HAAS indexing is not satisfactory. Looked at these variables in 98 machine. Date and time are present, but they can not be written to, and I do not know how to enable writing to them. Quick look at 2000 manual gave no useful information on setting date and time.
    daleman:
    Under HELP on the 98 machine I can not find date and time.
    2000 machine is currently tied up.
    Dec 2006
    49
    Quote Originally Posted by daleman View Post
    and time appears.
    hope this helps
    This is from the online manual.
    This only works on the newer machines mine is 2000 and it doesn't work.
    Thanks anyway.
    Dom
    Dec 2006
    49
    Quote Originally Posted by gar View Post
    070310-1700 EST USA
    daleman:
    Yep I've trawled up and down every setting and parameter from every mode and can find no date or time.
    The Haas service guy entered a service mode by pressing reset and one other key whilst turning on the machine and that gave him more options perhaps it needs setting from there. Does anyone know the buttons to press??
    Many thanks
    Dom
  1. Time to Buy
    By Gorillakilla in forum Stepper Motors / Drives
    Last Post: 06-24-2008, 09:52 PM
  2. milling time (not to be confused with hammer time)
    By barefoot0 in forum G-Code Programing
    Last Post: 05-03-2007, 12:18 AM
  3. X2 Conversion Time (shopping time)
    By Micro Rotors in forum Benchtop Machines
    Last Post: 03-04-2007, 06:11 PM
  4. Mazak 640t time and date set?
    By CHEEVES in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-13-2006, 02:45 AM
  5. Date for 3000 mem.
    By toolmkrman in forum Community Club House
    Last Post: 11-06-2003, 10:02 PM
