603,826 active members*
4,257 visitors online*
IndustryArena Forum > MetalWorking Machines > Syil Products > How to setup homing in Syil X3
Results 1 to 6 of 6
    Jul 2005
    10
    Hello Everyone,
    I mess up with machine but I don't know how to setup homing positions.
    Any help?
    Thank you
    Jun 2007
    3738
    Post Using Mach 3?
    Only the homing a problem, or have you broken a limit switch wire?
    Very easy to break. Look on diagnostic screen.
    Super X3. 3600rpm. Sheridan 6"x24" Lathe + more. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
    Jul 2005
    10
    Hi neilw20!
    For what should I look in the diagnostic screen?
    And if hopefully nothing is broken how do I setup soft limits?
    Thank you
    Jan 2007
    12
    Are you using mach 3? Go to the diagnostics page and see if the lights light up when you manually work the homing switches to see if they are working.
    You might get better luck asking mach 3 questions in the mach 3 forum.
    Sep 2006
    203
    Homing is the same on all machines running Mach 3. There is documentation for the procedure with Mach. The basics are homing to a known location. Jogging to the extents of the machine and entering those numbers off the DRO into the soft limits area.
    Direction, Commitment, Follow Through
    Sep 2006
    203
    You should check out the homing post with the video. Hope it helps.
  1. Syil X2 setup with Mach3
    By 43hudson in forum Syil Products
    Last Post: 03-27-2007, 01:52 PM
  2. New setup with Mach3 - Limits work, homing doesn't
    By journeyonline in forum Mach Software (ArtSoft software)
    Last Post: 03-22-2007, 03:09 AM
  3. what is the best homing and limit switch setup?
    By Bryscnc in forum Machines running Mach Software
    Last Post: 09-28-2006, 11:37 AM
  4. Homing
    By Sanghera in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-10-2006, 12:47 AM
  5. homing vs 0,0,0
    By planeflier in forum Mechanical Calculations/Engineering Design
    Last Post: 02-08-2006, 04:02 AM
