603,378 active members*
3,073 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How is a shaft attached to a shaft support rail ?
    Jun 2012
    18
    Have a basic question:
    How is a shaft attached(or mounted on) to a Linear Shaft Support RAIL ? Pics would be much appreciated.
    -Thanks.
    Jan 2008
    1556
    Holes in the round steel shaft are tapped (and bolted through the aluminium support).
  1. Precision - Shaft or Rail?
    By swisspnp in forum Linear and Rotary Motion
    Last Post: 05-13-2010, 01:34 PM
  2. Hollow shaft linear rail
    By GLynnC in forum Want To Buy...Need help!
    Last Post: 02-14-2010, 02:27 PM
  3. shaft support
    By smarbaga in forum Mechanical Calculations/Engineering Design
    Last Post: 04-17-2005, 02:58 AM
  4. Will 63" long Rail sag without using shaft support?
    By starCNC in forum Uncategorised MetalWorking Machines
    Last Post: 08-04-2004, 02:29 PM
