603,946 active members*
2,638 visitors online*
Results 1 to 6 of 6
    Mar 2007
    22
    How to size screen down
    I downloaded the mach 3 trial version thing and I cant get the whole window to fit on m screen. And there are no scroll bars. HELP!
    Jul 2005
    35
    Greetings Moto.
    Same thing happened to me, the problem is your monitor setup, not Mach.
    Goto your screen and click on a blank area with the right mouse button, click properties, then click Settings.
    You will see a slider bar marked with Screen resolution, just increase your screen resolution and that should fix your problem, fixed mine.
    -=7ofclubs=-
    Feb 2007
    4
    Sorry guys, this may not be the right place, but I was wondering if you help me? I have got the mach2 free copy which I would like to impliment on a cnc plasma cutter I am designing. I am currently running the program dry. On the toolpath there are sometimes a movement that the torch moves from one place to another without having to cut. Is there a way that I can make these movements faster whan the torch is not supposed to cut, without increasing the cutting speed?
    Mar 2003
    35494
    Use G0 instead of G1
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Mar 2003
    35494
    As for the original question, try downloading the new Flash screen. It should scale down for you, I think.
    Gerry
    Feb 2007
    4
    Thank you, will try that. Do you know where I might find it?
  1. Homemade Screen Printer/Silk Screen
    By Sbthomas13 in forum Machine Created Art
    Last Post: 02-14-2009, 01:35 AM
  2. X3 base size or minium bench size
    By kenrc in forum Benchtop Machines
    Last Post: 02-04-2007, 01:50 PM
  3. 21i screen saver?
    By bric2000 in forum Fanuc
    Last Post: 05-14-2006, 09:31 PM
  4. Screen size ?? What to expect?
    By murphy625 in forum CamSoft Products
    Last Post: 04-12-2005, 05:20 PM
  5. Ballscrew size -vs- project size
    By Alan T. in forum CNC Machining Centers
    Last Post: 10-19-2004, 02:53 AM
