603,894 active members*
3,056 visitors online*
IndustryArena Forum > CAM Software > Mastercam > How to stop table from returning home every tool change
Results 1 to 6 of 6
    Apr 2011
    Is there a check box or option in MC to prevent the table from going home after every tool change? Or is it a post processor problem? The line causing the trouble is G28 X0. Y0. Z0. A0. The machine is a Haas VF-2 and the machine type set in MC is Default mmd-5. Also what does the mm and mmd mean after the machine type name? Thanks
    Nov 2006
    418
    What version of MC are you using?
    Jul 2010
    117
    Im not sure if there is anything in the config to change this. I would think it is probably in your post
    BE NICE TO THE NERDS IN SCHOOL. THEY ONE DAY MAY BE YOUR BOSS
    Jun 2009
    65
    It's in the post. Very easy change to do, I changed mine to Not output the X0. but to just G28 Y0.
    Let me look that up and I'll get back with you.....
    Apr 2011
    Quote Originally Posted by John_B View Post
    X3
    Rstewart - I have never customized a post processor. Read a little about it but don't even know were to start. When I get a chance I will do some more reading. I'm assuming there are a few threads on the subject.
    Jun 2009
    65
    This line is most likely coming from peof$.
    It will look something like this.
    pbld, n$, *sg28ref, "X0.", "Y0.", e$
    You can change it to the following to remove the X0.
    pbld, n$, *sg28ref, "Y0.", e$
    Basically, you will want to delete the X0. in quotation marks.
    Hope this helps. :idea:
  1. Replies: 30
    Last Post: 11-02-2010, 09:09 PM
  2. Mach3 axis not returning to home
    By saltybugger in forum Machines running Mach Software
    Last Post: 01-18-2010, 06:57 PM
  3. Spindle stop prior to tool change?
    By nitemare in forum Mori Seiki Mills
    Last Post: 04-21-2009, 12:37 PM
  4. What G Code to Stop for Tool Change?
    By teamtexas in forum G-Code Programing
    Last Post: 09-10-2008, 02:12 AM
  5. Tool Change - Can I set it to auto stop?
    By inthezone in forum Fanuc
    Last Post: 01-23-2008, 12:56 AM
