Hello again,
Correct thickness????
Ok my manufacturer has come up with this method of production for the attached aluminium base I require.
"We shall have to make a " Hot Steel Dye weighing about 300 kgs from the tool room and then use a Pressure Die Casting Machine ,when the molten for is put in the steel dye it shall be clampem to a presuure of 250tonnes."
My question for the design attached. What thickness should the base be? We need it to be strong enough for shipment but it does not have to hold the weight of anything at all, it just sits there. Is 3mm too much... lighter the better for shipping.
Thanks for your answers and any comments you may have on his production technique would be appreciated too.
Cheers
Mr Lion
