586,042 active members*
3,668 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > how to run ac servo motor without driver
Results 1 to 11 of 11
    Jan 2018
    6
    hi all
    i have 2 ac servo motor
    1 of it no encoder on the back
    anther one without encoder
    how can i run it without its drive or encoder ?
    can i run it like steeper motors ?
    thanks
    Jan 2005
    15362
    Re: how to run ac servo motor without driver
    Quote Originally Posted by anowrosh View Post
    hi all
    thanks
    No to all your questions, you need a servo drive and an encoder for it to be of any use
    Mactec54
    Jan 2018
    6
    thanks
    Dec 2003
    24221
    hi all
    thanks
    When you say AC servo are they actually AC or BLDC versions, the motors are virtually identical, the difference is in the means of commutation.
    Any part No's?
    Al.
    Albert E.
    Oct 2018
    hi dear need help
    plz i have a bermaq cnc siemens control and siemens servos
    if i want to excchang the control
    can i stay all servos and buy driver to run them???
    Jan 2005
    15362
    Quote Originally Posted by kasem83 View Post
    hi dear need help
    Your drive control most likely is +/- 10v analog so yes it can be done, where you can have problems is with tool changers and spindle control normal axes control can be quite straight forward
    Mactec54
    Dec 2003
    24221
    hi dear need help
    Siemens servo's used at least three types of encoder feedback, the very early ones were resolver, you would need to find out the type fitted in order to sub in any drives.
    Most Siemens were also AC servo's, not BLDC.
    Al.
    Albert E.
    Nov 2013
    4373
    I experimented running an AC servo with a vector capable VFD. It worked OK.
    You can't use it for position control but you could use it as a spindle motor. The ratio of minimum speed to
    maximum speed is limited to about 10:1. Not withstanding those limitations it works.
    If you want position control then you need a genuine servo drive.
    To be honest mixing and matching servos and drives is likely to be problematic. Al-the-Man and mactec54 have way more experience
    and I would leave that to them. I bought a second hand 1.8kW AC Allen Bradley servo and matching drive for $600. It performs superbly
    despite not being the latest generation model.
    Delta, a Taiwanese company make great servos including on their latest models 24 bit absolute multi turn encoders.
    DMM is a Canadian company manufacturing in China who produce good quality servos and drives at very good prices.
    I suspect either of these companies could sell you a servo AND matching drive for less than you could get a drive for your Seimens servos.
    There is still a learning curve to get MATCHING servos and Drives to work let alone trying to program a drive from a different manufacturer!
    Craig
    Jan 2005
    15362
    Quote Originally Posted by joeavaerage View Post
    Craig
    Just thought I would post this as you posted about the Delta 24Bit multi turn encoder
    DMM now have added a multi turn 32 Bit Encoder Dmm do manufacture in China but it is there own company, all design and prototyping and some manufacturing is done in Canada
    https://www.youtube.com/watch?v=Vh1lxPZTmoE
    Mactec54
    Nov 2013
    4373
    Koool!!!
    Don't see a price listed yet.
    Craig
    Jan 2005
    15362
    Koool!!!
    Craig
    They have had it for a while but only just released it I'm sure there web site will be up dated soon this new encoder was mainly aimed at the OEM's and the Robot industry but can be used for any application
    Mactec54
  1. MCS-16H servo motor driver.
    By BigRalph in forum Fagor Automation
    Last Post: 06-04-2018, 08:55 AM
  2. different maker servo driver and servo motor.
    By aztec in forum Servo Motors / Drives
    Last Post: 01-11-2016, 08:52 PM
  3. Replies: 1
    Last Post: 09-03-2015, 09:38 AM
  4. Replies: 4
    Last Post: 09-08-2011, 11:41 PM
  5. old DC PM servo motor driver
    By visky in forum Servo Motors / Drives
    Last Post: 11-21-2008, 04:21 PM
