603,418 active members*
3,537 visitors online*
IndustryArena Forum > CAD Software > Autodesk > How too, AutoCad drawing to BMP/JPEG
Results 1 to 6 of 6
    May 2004
    83
    Its been years since I did it, Can any member describe the complete process for me?,
    My memory has got me this far,......Type viewres, then yes, then 20000, then export, then BMP, then save, then select object, and then right click, thats as much as I remember?,
    I want to print a drawing off, I have AutoCad 2000, and cad only has plotting, no printing, at least I cant find it,
    ..........any help would be appreciated,............Edmund............
    Edmund
    Mar 2003
    35494
    Ed, plotting and printing are the same thing. Just go to plot, and make sure your printer is selected, and you can print. There are a few options for what to print. Extents prints everything in the drawing. Display prints whatever is on the screen at the time. Or you can choose window to drag a window around what you want to print. You may need to adjust the scale to make it fit.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Dec 2003
    24260
    Also if you go to print, in the Print/Plot screen , look in the Config to see if the default printer is one of the choices, you can make this the default device to print with.
    Before you print select Scale To Fit if needed and look at the Full Preview before printing.
    Also your pen widths (even though its a printer) can be adjusted in this screen and also Device Requirements etc.
    Al.
    Albert E.
    May 2004
    83
    Quote Originally Posted by Holmes_ca View Post
    My memory has got me this far,......Type viewres, then yes, then 20000, then export, then BMP, then save, then select object, and then right click, that's as much as I remember?,
    Thank you Gerry, and also Al_the_man, I have tried both your suggestions (I think?), but get no printer activity, I'm a bit computer illiterate,
    Edmund
    Nov 2005
    1468
    To save as a BMP- type "Select All" then click File then Export.
    On your printer, can you print anything else on it? or is it just ACad that'snot printing? Is the device showing up on the "Plot" menu?
    I love deadlines- I like the whooshing sound they make as they fly by.
    Feb 2009
    Hi Dear !
    Type in command line as bmp out.
    A popup window appear.
    Then select the path to convert file.
    After select the object by check box.
    Thats it, you will have the .bmp files.
    Regads,
  1. autocad 2d/3d drawing/render into partmaster?
    By BulleTxMagneT in forum Dolphin CAD/CAM
    Last Post: 01-28-2008, 03:39 PM
  2. Autocad : Put a jpeg in the background to copy it?
    By jeeybee in forum Uncategorised CAM Discussion
    Last Post: 04-08-2007, 02:56 PM
  3. jpeg to dxf
    By sc_crasher in forum Uncategorised CAM Discussion
    Last Post: 01-20-2006, 09:57 PM
  4. Jpeg into Gibbs
    By moose in forum GibbsCAM
    Last Post: 12-30-2005, 07:28 PM
  5. jpeg convert to dxf...can I do this?
    By mredican in forum Autodesk
    Last Post: 05-05-2005, 05:32 PM
