603,979 active members*
1,358 visitors online*
IndustryArena Forum > CAD Software > Rhino 3D > How To Trace A Bitmap Or Image!!!!
Results 1 to 8 of 8
    Nov 2007
    3
    please tell me how to trace an image. i have to simply trace an image but when i try to do it manualy it doesnt turn out like the image. i was hoping there was a command to trace a bitmap or image to make things easier. if not please tel me the steps
    attached is the image to be traced
    Sep 2003
    1113
    I assume you have tried using the help files?
    Pull down - View
    Click Background Bitmap -- Place
    Then use the tools to trace your image -
    Is that it? Or are you looking for a Quick Import feature? I am too - but so far its the manual steps...
    :cheers: Jim
    Maybe you can find and use a vectorizer program to get to a form that you can import - like BMP to DXF or something - but for a simple image try the steps outlined.
    Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
    Mar 2006
    49
    Use a program called Inkscape. It is free and has a bitmap trace function, you can then export the file in pdf, AI, or eps and they will all open in rhino.
    Jun 2003
    2103
    For the best tracing in Rhino you have to have Rhino V4 and use a feature called pictureframe. Slick and quick but not automatic. For instance on this image you have posted, you could trace either the inside or outside of the blue hand or both for that matter. Just as a reminder, the image you posted is a copyright image. I downloaded it to do a trace for you in Rhino but I can't do this one due to the copyright.
    Mike
    Quote Originally Posted by jmedick View Post
    No greater love can a man have than this, that he give his life for a friend.
    Apr 2003
    470
    That's Easy to do took me les than 5 min in Adobe Illustrator to trace by hand, Rhino would have been even easier for me to do it accurately... use this as an excercise in using Rhino. I'd post the one that I did but as Mike said... it's copyrighted... I'm not going there. (Hope that's not too much of a shocker.
    Nathan
    Jun 2005
    260
    I second ozturbo's suggestion.
    Inkscape's vector conversion is pretty good, and Inscape is free, as in beer.
    Apr 2005
    3634
    WinTopo DXF (Free)
    Free DXF - vectorink.com
    Feb 2007
    1084
    Quote Originally Posted by Switcher View Post
    WinTopo DXF (Free)
    So what did you end up using? I usually just zoom WAY in and use splines to follow the curves.
  1. 3d relief from bitmap
    By walter in forum DIY CNC Router Table Machines
    Last Post: 01-02-2013, 02:16 PM
  2. How To Trace A Bitmap Or Image!!!!
    By jmedick in forum Rhino 3D
    Last Post: 11-03-2007, 01:25 AM
  3. Trace-A-Punch comments?
    By Laff Riot in forum MetalWork Discussion
    Last Post: 11-19-2006, 08:13 PM
  4. Easily trace an image into your CAD
    By Graphcon in forum News Announcements
    Last Post: 11-14-2003, 01:30 PM
