Originally Posted by
Niggo
Hi! I need to drive a 2.1A 1.1ohm unipolar motor with the linistepper but I dont understand which kind of resistor to change and where they are (is the wirewound 1 ohm 5w ? ). Looking to the tune page I calculate the resistor to use : 1 ohm // 1 ohm // 10 ohm for a 0,47 ohm so in theory if I find a resistor of 0,47 ohm can I use it directly instead of the parallel of resistors? How to calculate the watt of this resistor? Last thing: do you think is better to change the transistor or other component to drive my motor ? Thanks in advance!
