Dear friends,
Now more and more CNC routers’ users choose Syntec control system, we usually supply wireless handle wheel with the system for some fine adjustments. Here is a picture to show you how to use the handle wheel, hope it can help you.
MPG could be used under the“MANUAL”mode and“MPG Simulation”mode. When use
MPG to control the machine, each axis move need rotate the rotary switch in the middle of the MPG to corresponding axial file. (And keep this rotary switch off when not in use.). Under it, there is a Rate Rotary Switch. Choose X1, and the machine moves 0.001mm when rotating wheel rotates one grid. Choose X10, and the machine moves 0.010mm when rotating wheel rotates one grid. Choose X100, and the machine moves 0.100mm when rotating wheel rotates one grid. The rotating wheel rotates forward and the axis moves positive
Welcome to visit our website: cnc router | cnc engraving machine - ROCTECH CNC router for more information.
Best regards,
Fanny ([email protected])
