Customer sent drawing of assembly they need us to weld. At first glance it appeared to be an ordinary weldment. Not 5 minutes after I recieved drawings, customers calls. "I forgot to make notation all dim. are metric. and they are in millemeters. Material on both components is 440C. Due to the application they will be used they cannot be soldered and must be welded
So I reviewed further and did some quick setup and prototyping to make certain we could meet expectations regarding welding. Tried several clever setups and proved it out.
If you notice where the ball is to be joined to shaft, a small indentation to partially accept ball. That is the area I was wondering how it could be done. I guess it could be done on some of the newer high tech edm sinkers. We do work with a shop that has a wire edm that can run .0008 wire.
My question is how in the world are these pcs. going to be made. I'm able to weld them but was just wandering how they would be machined. Customer assured me they have vendor who is capable.
