I have a dxf file with what is a spiral path geometry. When I try to NC it in BobCad the tool rapids to the safe z height and then goes across the geometry to start the next spiral in the opposite direction. I'd like to eliminate the waste of it rapiding across, and simply move to the closest spiral arc and cut in the opposite direction. Is there an easy way to make each spiral arc opposite the proceeding one, so that BobCad will do what I want? Thanks.
Rob
