603,783 active members*
2,667 visitors online*
IndustryArena Forum > CNC Electronics > Phase Converters > Huanyang 2.2kw VFD, 0-10v 3600rpm settings?
    Jun 2010
    119
    I've been trying to get my vfd to be controlled from linuxcnc with a c41 pwm to 0-10v board. I'm getting my 0-10 ok, but i can't get the VFD to turn on. I've got it wired to VI and acm. All the settings i can find are for the 24k spindles. Can someone post the necessary settings for the above setup? It is an 1800rpm, 2hp, 220v., 60hz, 3ph motor. I'd like it to run at 3600rpm max or so, 120hz. It runs fine if I set it manually from the panel, just won't do anything from the 0-10v. I've tried quite a few setting combinations with no luck so far. I'm hoping someone has successfully set one up in this configuration.
    Thanks,
    Mike
    Nov 2008
    17
    You also need to:
    1) Put jumper between FOR (forward) and DCM. This tells VFD, that you want to spin CW. You can go fancier with relays, but jumper will do.
    2) Configure VFD to accept input from VI, not from operator panel. I believe for you VFD, you have to set PD01 and PD02 to 1 (default should be 0).
    Take voltmeter and measure voltage between VI and ACM. Do you have anything between 0-10V there? Does it move, when you dial speed?
  1. Huanyang Chinese VFD settings and manual here!
    By diyengineer in forum Spindles / VFD
    Last Post: 03-02-2025, 10:09 PM
  2. Huanyang HY01D523B help please?
    By Tony344 in forum Spindles / VFD
    Last Post: 10-22-2013, 01:27 PM
  3. Help Help Help - Huanyang VFd and spindle
    By PsychoPig7 in forum Phase Converters
    Last Post: 06-19-2012, 09:54 AM
  4. Huanyang inverter
    By mdileva in forum Phase Converters
    Last Post: 06-18-2012, 03:24 PM
  5. Mach3 CV settings vs. G-100 Plugin CV settings
    By Bfarn in forum Machines running Mach Software
    Last Post: 12-17-2008, 05:45 PM
