Hi Guys,
I bought one of these a while ago and still can't get it to turn on and off with the computer but I did have some luck with the settings.
Mine wouldn't run without smoking .
I have had that error you mentioned before after I set the DC braking switch (PD 030) I set this to 0 , DC braking invalid and I had no problems with that error afterwards
I did a reset PD013 setting 08 and then had to set it for Frequency Track running on PD025 (setting to 1) for it to work.
After a reset you set
PD013
PD005
PD004
PD003
Have you set the torque curve for the particular motor you have? This is set in the Table of settings for your particular model number (AFTER the PD010 settings in the manual)
It will have the settings for PD008, 009, 010, 015, 041 all in a row.
This is a good place to start from.
I am thinking of trying the Speed controller board from IMServices as it is compatible with VFD's for controlling spindle speeds but I don't know if it will work with the Chinese one. It's about $60 so is cheap enough to try.
Let me know how you get on. :-)
Rich
I am not completely useless.......I can always serve as a BAD example.
