588,079 active members*
4,766 visitors online*
Results 1 to 4 of 4
    Mar 2017
    Huanyang VFD - again
    Hate to beat a dead horse, but.
    I have a 2.2kw Huanyang vfd, or should I say a second one, toasted the first.I'm looking to use it on an industrial slicer. I wired the first one and set what I believed were the necessary parameters. Motor worked FWD/REV, stop, etc.
    Onboard pot would not function. I only want to use this vfd to slow down the slicer. Parameters were set as follows:
    PD000 lock 0
    PD001 source 0
    PD002 source 0
    PD003 main freq ? can't remember, there is only an asterisk in manual, however if settable I used 60hz
    PD004 base freq 60
    PD005 max op freq 60
    PD006 Interm. Freq 2.5
    PD141 Motor Volts 220V
    PD142 Current 15 FLA
    PD143 Poles 4
    PD144 RPM 1740
    Motor: 1 hp Leeson 220V, 60hz, 3P, 4 pole, 1740 rpm
    Jumper was set, I think, for the onboard pot. Pot would not function. Rpm was exceeding 1740 so I shut it down.
    Set PD004, base freq to 0.01 and vfd made a loud unpleasant noise when run pressed. I would like not to hear that
    noise again so any help would be appreciated.
    Dec 2013
    5722
    Re: Huanyang VFD - again
    003 could be set at 60, that is the start up speed, adjustable with the buttons or pot.
    004 should be set to 60
    142 seems a bit high, should be motor nameplate amps, around 3.2 - 3.6 or so for a 220V, 1HP, 3PH motor..
    Mar 2017
    Quote Originally Posted by Jim Dawson View Post
    Thanks Jim I think amps are around 3+/-,not in front of machine I think FLA was higher and that's what i set.
    Still waiting for new unit, weather slowed it down.
    Dec 2013
    5722
    Don't confuse FLA with locked rotor amps or fuse amps.
  1. Huanyang VFD Troubleshooting
    By stephen.morgret in forum Phase Converters
    Last Post: 01-22-2019, 03:14 PM
  2. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  3. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  4. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
