587,762 active members*
3,289 visitors online*
Results 1 to 6 of 6
    Mar 2007
    217
    Huanyang VFD & KFLOP
    So my Medium Format Router project is nearing completion.....for testing I have been manually setting the Huanyang VFD using the control panel on the front of it, and this isn't horrible, but I would love to be able to control it via KMotionCNC...and I assume this is achievable via any of several methods...the most eloquent of which would be via RS485 Modbus serial comm directly from the KFlop, but I don't know that I have the patience to work that out on my own.....obviously I can use PWM and a few i/o pins for on/off/forward/reverse/stop...but RS485 would be really slick....since I have a long history of reinventing the wheel, I thought I would simply ask for advice on how to proceed.....
    Thanks in advance for any thoughts/advice....
    Fish
    Dec 2003
    24220
    Re: Huanyang VFD & KFLOP
    There are a couple of Modbus plug in's specifically for the Huanyang, the best is by Royaumedeole.fr , there is a long Thread on it on the Mach forum.
    Max.
    Albert E.
    Mar 2007
    217
    Thanks Al.....
    but a Mach3 plugin doesn't really help me with KMotionCNC....unless the Mach3 Plugin somehow works with KMotionCNC and I missed the memo....I was just hoping someone had already worked the modbus out for KMotionCNC....but I can certainly get up and running with analog voltage and various i/o bits....
    Thanks!
    Fish
    May 2006
    4052
    Hi Fish,
    If you just want to turn the Spindle on/off and occasionally set the speed you might try connecting directly to a PC Serial port. There are some free relatively simple PC programs to talk Modbus. If you can get that to work then it is relatively simple to make KMotionCNC invoke those PC programs for M3, M4, M5, and S. Here is a link to a related discussion on our Yahoo Group.
    https://groups.yahoo.com/neo/groups/.../messages/9509
    Even if you eventually want to connect directly to KFLOP for real-time ModBus control its a good idea to verify functionality with the PC first.
    HTH
    Regards
    TK
    http://dynomotion.com
    Dec 2003
    24220
    Quote Originally Posted by Fish4Fun View Post
    Fish
    One thing to be aware of, Huanyang do not use the standard Modbus register methods, that is why a couple of special ones have been written for Mach.
    The details are on the Modbus plugin on the Mach site.
    Al.
    Albert E.
    Mar 2007
    217
    Quote Originally Posted by Al_The_Man View Post
    Al.
    Yep....I am aware, but thanks for the tip....If there is any "good news" it is that I am NOT already familiar with Modbus, so learning the Huanyang rendition will not require me to "unlearn" anything if I decide to pursue it, lol.....I am not really certain that for what I do it is even worth the effort.....this new machine is so fast that I spend more time doing tool changes than I do cutting, lol. If I do ever pursue it, I will post any success I have here.
    Thanks!
    Fish
  1. Huanyang 2.2kW VFD.
    By atc40 in forum DIY CNC Router Table Machines
    Last Post: 10-19-2014, 04:33 PM
  2. Huanyang HY01D523B help please?
    By Tony344 in forum Spindles / VFD
    Last Post: 10-22-2013, 01:27 PM
  3. Huanyang VFD
    By dwschool in forum Mach Lathe
    Last Post: 02-06-2013, 05:40 PM
  4. Huanyang VFD
    By moonman5 in forum Phase Converters
    Last Post: 01-19-2013, 05:43 AM
  5. huanyang 2.2kw vfd problems
    By terryprice68 in forum Phase Converters
    Last Post: 01-08-2013, 02:46 AM
