603,365 active members*
3,983 visitors online*
Page 14 of 29 4121314151624
Results 261 to 280 of 574
  1. #261
    Jan 2017
    35
    Re: Huanyang VFD Macro/ Plugin
    Hi Dan,
    to be honest, that is because I am totally clueless, how to configure it.
    In the plugin, for the Sact Labelnumber, I should fill in something in the range of 20000-20999.
    As I have no clue where to get the number from, I used a dice, counted all the dots and filled in 20200.
    Of course, I didn't expect anything from this.
    At the same time, I find it kind of annoying it is always fixed to 0, but I thought (from documentation) it needed an index pin from the spindle, which of course isn't there.
    I would truly appreciate it if you could help me with this.
    Kind regards,
    Jack.
  2. #262
    Mar 2010
    813
    Quote Originally Posted by P.Passuello View Post
    Thanks Gerry that's what I thought is meant to happen.
    I am under the impression that the Sact is got by reading the VFD and then displays it in UCCNC.
    If this is the case then how can it be wrong everytime. ( of course I could be entirely wrong on this and talking through a hole in my head, Dan will know.)
    What the plugin reads and fills Sact field with is (" Sset * spindle override = Sact")
    UCCNC is always going start with the min rpm in UCCNC spindle setup and override at 100%.
    Dan
  3. #263
    Mar 2010
    813
    Ok, so if 20200 is set in HYPLUGIN config you now need to go to screen edit and edit Sact field.
    Goto CONFIGURATION / GENERAL SETTINGS / Edit screen. To go to your Run screen hold down shift key and press the "Run" tab on top, now click on your "Sact" feild (A red rectangle will appear around it) in screen edit window make sure "Selection tab" is selected and change the labelnumber from "870" to 20200, than click apply settings, click on File tab on top of window than click "Save screenset".
    Dan
  4. #264
    Jan 2017
    35
    Hi Dan,
    Wow, awesome! That works like a charm!
    To test it, I entered S12000 in the MDI, the Sact field shows the Sset value * override value, the way I liked it, and when I turn the pot to 200%, it reaches 24000RPM!
    So now I can see what I'm adjusting the speed to with override, without doing the math myself!
    Thank you very much!
    BTW, when I first tried to accomplish that a week ago, I was not able to switch to the Run screen, and thought the screen editor was just buggy, instead of me. :-)
    So this way, I could add a Amp field too?
    Kind regards,
    Jack.
  5. #265
    Mar 2010
    813
    Yes, use screen edit to copy Sact field and put where you like. Don't forget to change label number to match amp field in config.
  6. #266
    Mar 2003
    35494
    Yes.
    I've also requested a new field from CNC Drive, that will show the SSet * Override value. It probably won't be in the default screen, but should be available for use in the next release.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
  7. #267
    Jan 2017
    35
    Hi Ger,
    funny, I had requested it too, so there are more requests.
    Anyway, Dans plugin takes care for it now.
    And I have added the Amps field on some spot I could free a bit of space:
    Not very pretty, but it will do. :-)
    BTW, I use a touch screen, that works very nice with UCCNC!
  8. #268
    Mar 2010
    813
    Nice...LOL. I put mine in same place. If you make the Cycle Stop, Free Hold and Single Line buttons height a little smaller it gives you some room.
    Dan
  9. #269
    Mar 2010
    813
    Quote Originally Posted by JackBerkhout View Post
    I did and thought the same when first played with screen edit.
  10. #270
    Jan 2017
    35
    Hi Dan,
    I actually placed the those buttons closer to each other, so from top to bottom, I decreased t Y positions, I thought by 15 the first 30 the second and so on...
    jack.
  11. #271
    Jan 2017
    35
    Hi Dan,
    may I ask, how did you develop the plugin? Which language did you use (C#, C++)? Which IDE do you use for it?
    I'd like to learn it too. I do know both C# (to a degree) and C++.
    Kind regards,
    Jack.
  12. #272
    Mar 2010
    813
    C# Good place to start is Documentation folder in UCCNC folder.
    Dan
  13. #273
    Jan 2017
    35
    Hi Dan,
    excellent, thank you!
    Jack.
  14. #274
    Mar 2010
    813
    Hello All,
    There's a lot a different Test versions in the past pages of this thread so wanted to put out the latest recommended version and fairly confident "Final Version". You won't get a "You are Connected Window" but will get a window if there's a connection problem.
    Download Here>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>HY10.rar.zip
    Dan
  15. #275
    Dec 2005
    238
    Hi Dan,
    The new Rs485 adapter just arrived in the mail.
    I quiclkly grabbed it and went out to the workshop and installed it.
    The spindle started with the correct minimum speed for the first time which it had never done before. :banana:
    I then stepped through the speeds and it also worked as it should.
    I restarted the pc and VFD several times and retested. So far so good.
    I installed HY10 and retested. It also works as it should.
    I haven't had much time to look at it properly and will test some more when I get some time.
    I realize my test was only quick but I was able to break the last ones in minutes so it looks encouraging.
    I had tried other drivers for the Prolific adapter as you suggestedbut with no success.
    The new one is a CH340 adapter.
    I have to work late tonight so probably do won't get a chance to test further today.
    Just thought I would let you all know how the new RS485 went.
    Thanks to everyone who has given help with this
    Cheers
    Peter
    :cheers:
    The ingenuity of idiots is unlimited.
    http://www.youtube.com/user/cncnutz
  16. #276
    Mar 2010
    813
    Hi Dan,
    Cheers
    Peter
    :cheers:
    Great News!!!
    Could you please mail me the old RS485 so I can smash it with a hammer...LOL
    Happy you got it going, use HY10 it has connection test back, you WON"T receive a window on startup but will if there's a problem. It also waits for connection to be set before it starts so it don't miss any commands.
    Dan
  17. #277
    Dec 2005
    238
    Quote Originally Posted by Dan911 View Post
    Great News!!!
    Dan
    Do you have a big enough hammer?
    Cheers
    Peter
  18. #278
    Dec 2005
    238
    So I opened up the RS485 adapter tonight when I got home from work and had a look at it.
    I noticed 2 things about it.
    1st the metal case of the USB plug was not soldered to the circuit board. Not a problem as far as the operation of the adapter goes but mechanically it will cause premature failure of the device as it puts strain on the USB connectors pins and gives a clue as to the quality of the build.
    2nd I noticed that the USB to serial IC is unlabeled and it is not because the name has been scratched off as is sometimes done to hide a critical IC's identity.
    I suspect it is a copy of the Prolific 2303 chip and was not working correctly with the drivers.
    The utility on the prolific website identified it as a PL 2303 series chip so maybe it is genuine but I find it hard to believe they wouldn't put their name on it. This IC is also a well known target of counterfiet though the Prolific drivers aren't meant to work with it at all.
    Prolific Adapter (Click to enlargen)
Name:	Prolific adapter.jpg
    The CH340 adapter is a better build quality and the USB to serial IC is labelled (Click to enlargen)
Name:	CH340 Adapter.jpg
    Both use the Max485 line driver IC for output to the VFD which converts RS232 to RS485.
    Just thought you might be interested in seeing what was inside and regardless of wether it is a fake or just faulty I will be dealing out vengeance on this adapter. :devious:
    Cheers
    Peter
  19. #279
    Mar 2010
    813
    Good info for any in the market to purchase one of these, there's many to choose from on eBay.
    Dan
  20. #280
    Jan 2017
    35
    Hi Dan,
    I have just tested HY10 and could not find any issues with it.
    Thank you very much!!!
    Kind regards,
    Jack.
  1. Accessing Macro Variable from another macro
    By ex-egll in forum Mach Wizards, Macros, & Addons
    Last Post: 02-01-2014, 06:52 AM
  2. Replies: 2
    Last Post: 12-19-2012, 01:28 PM
  3. Replies: 3
    Last Post: 02-13-2012, 07:20 PM
  4. Replies: 2
    Last Post: 03-27-2009, 09:15 PM
  5. Convert Fanuc Macro to Fadal Macro
    By bfoster59 in forum Fadal
    Last Post: 11-09-2007, 06:41 AM
