Originally Posted by
garrett1812
Hi all,
I have done some reading, and think these are the important parameters to set. Before I get started, can someone please check if these settings are correct, or if there is anything missing?
VFD: Huanyang HY03D011B (110V, 3.0KW)
Spindle: Huanyang GDZ-65-800C (800W, 110V, 400Hz, 24000RPM)
For now I want to set this up to use the potentiometer for speed control. Later this will be connected to a Buildbotics controller by RS485.
PD000 = 0
PD001 = 0
PD002 = 0
PD005 = 400
PD004 = 400
PD003 = 400
PD072 = 400
PD008 = 110
PD011 = 120
PD141 = 110
PD142 = 7
PD073 = 120
PD000 = 1
Then later, when connected to the controller, change these settings:
PD000 = 0
PD001 = 2
PD002 = 2
PD163 = 1
PD164 = 1
PD165 = 3
PD000 = 1
Thank you!
