587,167 active members*
3,644 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > hurco hawk x axis encoder error or is it.
Results 1 to 13 of 13
    Sep 2005
    26
    Hi all
    Well i have a more urgent problem
    Have been testing the hurco today.cutting a dia to check if it cuts round for starters.
    All seemed fine.Then ran the x and y axis up and down reasonably quick a few times.
    Then Ran the same program again.X axis moved about a millimeter.So i thought encoder.
    Which was a bit strange because its had a new one fitted just over a year ago.So i took
    the complete servo motor and fitted to my other hawk and all seemed fine.swopped it back same
    thing happen again.swapped it back to other one,no problem.But the last time i put the original
    motor and encoder back on it wont calibrate in the x without saying x axis error or encoder error.
    So for the last time i put it back on my other machine thinking i should get encoder error.I didnt
    Any ideas anyone please
    Neal
    Dec 2003
    24223
    Well it seems you have eliminated the motor/encoder so the next most likely suspect is the drive?
    There is also a possibility that the encoder input on the controller has a problem, but I would suspect the drive first.
    Can you swap these also to eliminate?
    Al.
    Albert E.
    Sep 2005
    26
    Thanks Al
    Are the x and y axis drive boards interchangeable.So i could just swap those and see if error goes to y axis
    Neal
    Dec 2003
    24223
    Check the part/model number, that should indicate if they are interchangeable, also if the x y motors are the same size?
    Al.
    Albert E.
    Feb 2009
    6028
    If its the baldor drives, they are.
    Sep 2005
    26
    thanks Al
    Just as you thought swapped x and y error followed.Just to make sure put board in the other machine
    and error followed.Thanks Al
    Just one more question.Is there anything else that can make the boards go.Dont want to buy a new one
    just for another component to blow the board again.
    Thanks again Al
    Dec 2003
    24223
    The motor looks good so the only other thing usually would be a damaged cable?
    Al.
    Albert E.
    Sep 2005
    26
    Thanks Al and others for replies
    New problem.Pretty sure drive board was part of the problem.Put board in off other machine along with
    servo motor and encoder so pretty sure its not those.Now the x axis is still losing position in the x,up to 10mm worst case in one direction ie table moving right.
    Ideas welcome
    Neal
    Dec 2003
    24223
    Sounds like it is something mechanical, you will need to eliminate this as a problem first.
    Especially in one direction only?
    Al.
    Albert E.
    Sep 2005
    26
    is there anything else mechanical to check apart from leadscrew nut or what ever you call it
    cheers Al
    Dec 2003
    24223
    If you can, with the power off, put a dial gauge on the final mover (table) and turn the motor shaft by hand within the range of the dial gauge, then turn exactly the same amount in the reverse direction, see if it returns to 0.
    Al.
    Albert E.
    Sep 2005
    26
    Me again
    Just like to say a big thank you to Al the man.Did some messing earlier and took the round connector apart
    going into the servo drive motor and found one of the small black wires had come free.Would this cause the
    symptoms i mentioned.ie make it loose position also could it have been this which made the board go
    Thanks again to all who replied
    Neal
    Dec 2003
    24223
    Quote Originally Posted by nealg View Post
    We may never know!
    Put it down to Gremlins!
    Al.
    Albert E.
  1. Hurco hawk 30 z axis board repair
    By nealg in forum HURCO
    Last Post: 01-11-2013, 03:10 PM
  2. Hurco Hawk 40
    By JohnRF in forum HURCO
    Last Post: 10-31-2012, 05:15 AM
  3. Hurco Hawk 40
    By brucemazor in forum HURCO
    Last Post: 08-19-2011, 05:56 AM
  4. Replies: 4
    Last Post: 12-02-2010, 12:37 PM
  5. Hurco Hawk 30
    By jack_1960 in forum Uncategorised MetalWorking Machines
    Last Post: 10-21-2007, 01:27 PM
