603,965 active members*
2,728 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco KM3P Dual Axis Board problems..
Results 1 to 1 of 1
    Nov 2014
    Question Hurco KM3P Dual Axis Board problems..
    I have a two Hurco KM3P v130 & v162 with Max 32. Both machines are has trouble with dual axis boards. When I tried to calibrate the bed, I got a motion error. The x/y dual axis uses -007 eproms, the z/s dual axis has one -007 for Z and a -317 for the spindle. The Max 32 used a DSP board, the dual axis boards won't work without changing the executive file on the hard drive. The V130 and V163 I think are DSP eproms,
    How can I get Max 32 upgrade? or change executive file? I found couple of documents from www.tutorialanswer.com there is hiding menu in max 32 enter 200 enter and helping test axis boards..
    Dual Axis Boards;
    415-0176-001J
    415-0176-001J
    415-0176-006H
    415-0176-007H
    Thank you.
