586,070 active members*
3,556 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > HURCO KM5P Max 32/DSP hard drive type?
Results 1 to 6 of 6
    May 2013
    20
    Hurco KM5P Max 32/DSP I replaced a dead 4.5 v memory battery on the board but when I start machine it wants me to choose hard drive type? I realize that probably all memory went away so thats why it wants me to choose settings. I do not know the previous settings and I do not have any floppy drives. Is there a way to check history of settings ? And if so, How do you go in and check previous settings Thanks in advance Ron
    Apr 2021
    14
    Re: HURCO KM5P Max 32/DSP hard drive type?
    Did you ever figure out the hard drive setup? I'm having a similar problem with my Hurco BMC-20.
    May 2013
    20
    Quote Originally Posted by tedhur View Post
    yes It works now, I had a dead memory battery and it came up with a different page on start up , i entered the new numbers and it took off and runs. I'm not the expert but I will try to help. Thanks Ron
    Apr 2021
    14
    If your situation in a setup menu, did you enter a Disk Type? If so, did you enter the disk type based on a reference somewhere or did you just chance it?
    I think I have a dead memory battery as the board seems to lose setting info after a few days of non-operation.
    Thanks,
    Ted
    May 2013
    20
    Thanks,
    Ted
    Here is what I put in and it loaded and ran , after I bought a battery pack that held regular batteries and plugged back into board, air pressure good , started machine and it came up to that page for settings, I have Rev 1.64 entered following hard drive type 48, #cylinders 1024, heads 16 precomp 0, landing zone 0, # SECTORS 50, capacity 400 , RAM CONFIGURATION 4 mb, entered , restart worked, homed xyz , now able to jog , hope this helps out . I did not load and floppy drive to bring back any settings Rondal
    Sent from my iPhone
    Apr 2021
    14
    Thanks, Ron, for the information. Can't hurt to try your setting, so I'll try Type 48 and see what happens.
  1. KM5P Hurco
    By Rondal in forum HURCO
    Last Post: 12-28-2020, 01:25 AM
  2. Hurco KM5P
    By jayrak in forum HURCO
    Last Post: 01-11-2019, 07:32 PM
  3. Hurco Hawk 2u Hard drive bad with ultipath Software
    By Kcarpenter1986 in forum HURCO
    Last Post: 01-03-2019, 03:26 PM
  4. Replies: 0
    Last Post: 01-23-2017, 09:28 PM
  5. Hurco BMC40 Hard Drive Replace
    By regocolm in forum HURCO
    Last Post: 11-16-2016, 08:19 PM
