587,726 active members*
3,424 visitors online*
IndustryArena Forum > MetalWorking Machines > HURCO > Hurco Mb1/Mach3 retrofit
Results 1 to 10 of 10
    May 2007
    My ultimax II controlled Mb1 has gotten really expensive to keep running these days, especially for a hobby machine. It is in need of a retrofit and I have a few questions.
    1- Utilizing a pc and Mach 3 software how do I interface to the servo drives? Do I need some kind of step & direction to analog signal convertor? I'd like to keep the original hurco max 400 drives if possible.
    2- Will the VFD a mitsubishi freqrol z200 be compatible as well? What about the spindle brake?
    3- What is a good source for the breakout boards and all misc. hardware that I will need?
    4- Encoders..What do they do? Do I need any??
    This will be my first retrofit so I have and will be searching here for as much info. as I can find on this subject. Has anyone here done this with an MB1?
    Thanks in advance.
    Apr 2007
    9
    hello silvio what you need is a convertor step / dir to + /-10 vdc I can provide them. hablas español?
    Oct 2006
    20
    Hurco MX-400 Amplifier USED
    Quote Originally Posted by mariolizano View Post
    Hello, anyone know where i can buy the Hurco MX-400 amplifiers in used condition for a good price?
    Let me know
    MLD
    email: [email protected]
    Oct 2006
    20
    Hurco MAX-400 Amplifier USED
    Hello,
    Anyone know where i can purchase Hurco MAX-400 Amplifiers USED for a good price.
    Let me know
    MLD
    Oct 2008
    78
    Look at EMC2 with the Mesa 5i20 and 7i33 cards. I'm putting the final touches on a SM-1.
    Donnie
    Oct 2008
    42
    Do not buy Hurco MAX400 amps. You are way better off replacing them with something else. I suggest Servo Dynamics.
    Buddy
    www.amtsinc.com
    Oct 2008
    42
    EMC2 is run on a Linux computer and is a closed loop system(good). This takes some time to do but is a much better system than Mach3 which is open loop(bad). The Mach3 is much easier to do though but EMC2 is worth the trouble.
    Buddy
    Feb 2009
    6028
    hurco
    My 2 cents, what ever Hurco uses, USE SOMETHING ELSE! They have to be the most trouble prone machines i've ever worked on !
    Oct 2006
    20
    what servo dynamics amp replaces the hurco max-400 AMP? where can i get them used or new and what is the cost can someone email me an ebay link or a website of where i can buy one used? how much do they normally run for $$
    MLD
    [email protected]
    Feb 2010
    hello,
    anyone know where i can buy the Hurco MB1 software on digital tape mc60?
    It is running like that ant i don't want to much expenses.
  1. Hurco
    By jawwad in forum HURCO
    Last Post: 11-11-2006, 06:54 PM
  2. Hurco Kmb-1m retrofit with Ajax system
    By cybeeria in forum Centroid CNC Control Products
    Last Post: 08-04-2006, 05:13 AM
  3. Retrofit on Hurco
    By Steve@Reliance in forum HURCO
    Last Post: 02-07-2006, 07:28 PM
  4. hurco
    By RCLAYTON in forum MetalWork Discussion
    Last Post: 12-23-2005, 03:32 AM
