587,997 active members*
1,965 visitors online*
    Dec 2003
    24220
    Hydraulic danger
    Triple M Metal Corp., a Brampton company that recycles metal, was fined $75,000 for a violation of the Occupational Health and Safety Act after a worker was injured.
    On May 25, 2010, at the company's facility in Hamilton, a worker was using a torch to cut a railcar coupling. The coupling contained a cylinder that held compressed hydraulic fluids. The torch pierced the cylinder, allowing the hydraulic fluids to escape and ignite. The worker suffered second and third degree burns.
    A Ministry of Labour investigation found that the company's procedures to identify hazardous materials failed to ensure that objects containing compressed hydraulic fluids were not cut using torches.
    Triple M Metal Corp. pleaded guilty to failing take the reasonable precaution of having a safe procedure to ensure that objects being cut contained no hazardous materials.
    Albert E.
    Jul 2005
    12177
    Quote Originally Posted by Al_The_Man View Post
    ...The coupling contained a cylinder that held compressed hydraulic fluids.....
    Probably a ultra heavy duty gas shock replacing coil springs.
    Mar 2006
    2712
    Beware of charged hydraulic accumulators. They do not automatically "dump" their pressure unless designed to do so.
    Dick Z
    DZASTR
  1. Hydraulic danger
    By Al_The_Man in forum Safety Zone
    Last Post: 01-04-2012, 04:04 AM
  2. Danger: Exploding Capacitors
    By Eurisko in forum Stepper Motors / Drives
    Last Post: 03-02-2008, 05:48 AM
  3. Tiredness Danger
    By ImanCarrot in forum Safety Zone
    Last Post: 02-10-2007, 11:18 PM
  4. induced voltage danger?
    By Oaktreeman in forum Community Club House
    Last Post: 05-25-2006, 05:12 AM
  5. Danger Tunes: Your Emails
    By WallCrawler in forum Community Club House
    Last Post: 04-15-2004, 05:03 PM
