587,626 active members*
3,394 visitors online*
IndustryArena Forum > MetalWorking Machines > Cincinnati CNC > Hydraulic oil in electrical cabinet??
Results 1 to 10 of 10
    I've been dealing with my coolant leak I talked about in my other thread, thought i found the source of the last one, then noticed the leak was coming from the weep hole in the bottom of the electrical cabinet, then I noticed the liquid wasn't coolant, it is hydraulic oil, it has covered most of my boards, and for the life of me I can't find how its getting in? Has anyone dealt with this situation before? Is there a pressure sensor with a small feed line to the cabinet? Is it sabotage? Luckily the only malfunction I have noticed is the M9 not turning coolant off, I guess its time for several cans of electrical cleaner, air and rags. Thanks for looking!
    Re: Hydraulic oil in electrical cabinet??
    Its an Avenger 250T by the way.
    Feb 2009
    6028
    Check the cable going to the hydraulic pressure switch. Ive seen those leak through the cable, not easy to find.
    Sent from my SM-T813 using Tapatalk
    Thanks, I'll check that out, finally got some cleaner in so I'm going through it now.
    That is exactly what it is, i sliced some insulation off where it comes through and the inside is saturated with hydraulic oil, thanks again!
    Sep 2010
    1765
    Quote Originally Posted by underthetire View Post
    IMPRESSIVE REPLY!!!!
    Sent from my SM-G900V using Tapatalk
    Took the connector off the pressure switch this morning and there was about 1/4 cup inside the connector housing, wow. Now to try and find a replacement...:tired:
    Anyone know the specs for a replacement? I've looked in my manuals and the only mention i can find of it is location in the diagrams. I have found a lot of identical looking switches online but the PSI ranges vary.I see in the diagram it says set at 450 PSI decreasing, so 450 PSI max on the switch? Sorry for all the questions, I'm not extremely privy on hydraulics.
    Having trouble finding this part, got a hold of Fives and they quoted me for a pressure switch, I looked it up on their website and its not the same part, I found the pressure switch they quoted me and its on the opposite side of the tank. I tried capping the line and leaving the switch out just for giggles and obviously got an error, a hydraulic pressure switch error. here is a pic of each one. They list a hydraulic pressure switch that looks identical but say it doesn't match my serial number, is it possibly a different part that happens to look like a hydraulic pressure switch? The tee that this sensor is connected to comes out of the manifold, and the other side of the tee goes to the pressure gauge that is next to the tank fluid level gauge, it is not connected to any other part of the system with hydraulic lines. Any ideas? I've got parts piling up and they aren't returning my emails now.Attachment 362462Attachment 362464
    Thanks again for looking
    here is a reference from the manual, my finger is pointed where this sensor/switch is locatedClick image for larger version.
Name:	hyd manual.JPG
  1. Haas Electrical cabinet keys.
    By Ken_Shea in forum Haas Mills
    Last Post: 02-25-2016, 02:51 AM
  2. Picture of electrical cabinet door key?
    By cordvision in forum Tormach Personal CNC Mill
    Last Post: 03-15-2015, 07:14 PM
  3. JUST COOLANT PROOFED MY ELECTRICAL CABINET
    By keen in forum Tormach Personal CNC Mill
    Last Post: 12-05-2014, 10:16 PM
  4. CNC Router Electrical Cabinet
    By oagag in forum Uncategorised WoodWorking Machines
    Last Post: 08-04-2014, 10:07 PM
  5. Electrical cabinet on my Arrow 750
    By magic0123456789 in forum Cincinnati CNC
    Last Post: 02-27-2013, 01:35 PM
